Hunter 42 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Stern Rail Seat
posted 10-07-2008 by Terry Cox
The leg I made from recycled 7/8th inch tubing and fittings. The tip is a crutch foot.
Standard SS tubing/fittings
The white board is 3/4 inch thick Seaboard XL, which means extra light and more like plywood. The piece is cut 12 inches wide by 18 inches long. Very strong stuff.
Seaboard XL
The rail feet are also Seaboard material. The P42 rail is one inch OD. The foot slot I cut 1/16th inch less on each side so that it pops into place. Each 3/4 thick rail foot is 1 3/4 wide and 2 1/4 long. I used three inch long flat head bolts with nylock nuts to secure the foot to the board.
Rail feet
The admiral got these fold up stadium seats from Big 5 Sports.
Stadium seat
The seats have four holes on the underside that take a size 14 screw. They secure the seat to the Seaboard.
Seats fastened to the Seaboard
Both the leg and seat fold up for compact storage.
Folds up nicely
Another shot of the underside
The rail feet slide on and pop into place. The seat is level unlike what the photo shows.
Mounted on the pushpit rail
The seat is very strong and comfortable. It also gives a good view of your course while under sail. I made one for each side of the boat.
Very strong attachment
Another shot of the rail feet.
Another angle shot.
A different angle shot
The seat folds up and hangs on the outside of the life lines where it is out of the way.
Hangs out of the way
Click image for largest view
