Hunter 260 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
H260 Tiller Downhaul
posted 10-07-2008 by John Revenboer
The Rudder Downhaul on the Hunter 260 really sucks and the factory is unwilling to change the design. It has been a problem since day 1.
Tiller Downhaul Mod
I solved the problem by adding a small boat trailer winch. Now anyone can easily pull the rudder into the down position with only a socket wrench and the winch holds the rudder securely in the down position.
Problem Solved
Click image for largest view
