Hunter 260 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Rudder mods compressed
posted 10-07-2008 by Jeff Peltier
I added a 2 * 10 * 10 gage SS strap to the top for added support of the plates. Its important to hold this in a jig and weld in a pattern that minimizes warping to ensure verticle alignment. I was able to get mine within 1/8 in 4 which, no doubt is within factory tolerances.
rudder plate support
Another shot of the added strap. The strap allows the load to be spread more evenly over half the tube instead of just 2 points as in the butt weld.
post strap
This is what I use to keep the rudder in the down position. The combination of the spring and the wrap around the stanction is enough to keep the rudder down unless it strikes an object.
rudder spring
This shows how the spring was mounted. Note the light line that holds the spring when not in use and the clevis which is easier to hook to the spring.
spring view
This is my version of the motor connection. A 1/4 rod, threaded on both ends with a spring loaded ball connection on the rudder end for quick disconnect.
Motor connection
A spring loaded ball joint was used on the rudder end for a quick disconnect. Note the light spring and line used to hold the rod for quick reconnect.
Disconnect
Click image for largest view
