Hunter 260 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Rudder/Motor Steering Linkage
posted 09-12-2008 by Multiple Contributors
Connecting the engine and rudder so they swing in unison allows the H26/260 to back and turn much easier. There are numerous ways to rig your boat -- a lot depends on the type of engine you have. The two most common manufacturers of this connection are E-Z Steer and Goldeneye. Google on E-Z Steer or Goldeneye Auxiliary Motor Link Steering Connector Kit Also parts can be fashioned from materials purchased at your local hardware store. Ideally, you want a install and forget setup that requires no brackets and no adjustments when raising or lowering the engine. Depending on the solution, the cost will be well below $100. Heres some pictures that will give you an idea of what it looks like:
As we find other examples well post them here.
