Hunter 260 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Companion way doors
posted 03-24-2021 by Willemvan
Click for larger view
Could not decide which wood to use so I used some left over 3” x3/4” oak hardwood flooring. Mounted polycarbonate on the outside as I did not have tools to dato. also used stainless pin hinges so I could remove doors easily.
Copyright 1997-2024 SB Owners, LLC
All rights reserved.
