Hunter 240 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Cheap Slap Silencer
posted 02-02-2009 by Per Albinsson
This is the low budget silencer for your flat transom. A foam sleeping pad, two ropes, one on each side and a slit for the rudder. You also need a boat hook to push it under the transom. It will effectively kill all those small evil waves who keps you awake all night.
Click image for largest view
