Click for larger view
It looks really good but I havent decided what needs to go in it
Shelf Dimensions
32 x 7 3/8 Outside Dimensions
15 x 6 3/8 Inside Dimensions (times 2)
8 high vertical dividers ( 3/4 Plywood )
6 3/8 x 32 bottom ( 3/4 Plywood )
1 1/2 x 32 side pieces ( 2 x 4 on edge ripped into 1/2 strips )
Screws are Number 8 Flathead 1 1/2
Power strip is mounted with Number 8 Flathead stainless 1/4 x 20 with SS Nylon Lock nuts.
