Hunter 23.5 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Table and increased storage
posted 10-07-2008 by Ed Allen
This a variation on a theme presented on this forum to add storage space to the 23.5. Quarter-inch plywood, extruded aluminum channel, and construction adhesive was used.
Storage cabinet
I used Stainless Steel clips and screws to hang our boat hook just under the companionway.
Boat Hook Storage
This is the h23.5 table in the position for use. It would really be nice if a gripping surface or lip could be added to keep things put!
23.5 Table
This shows the prop-stick and hinge where the table is mounted to the galley housing.
Table detail
Click image for largest view
