Hunter 23.5 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
23.5 Keel Photos
posted 10-07-2008 by Dave Royce
This is the keel mounting bracket. Note the shim material on the lower part of the bracket. With no shim material in the upper part of the bracket the centerboard has alot of lateral swing.
Keel Mounting Bracket
I installed the keel on the bracket and measured for the location of the new shims. 6 from the top of the barcket.
Location for new shims
I cut two new 1 shims the full width of the bracket. I clamped them on the inside of the bracket and drilled three screw holes. No the tough part. I taped and inserted screms from the inside. It took all Saturday afternoon.
New Shims installed
Another look at the shims
Lower shims once more
This is a piece of the old centerboard sleeve and the old pin. Note the piece of cardboard in the sleeve. To much play,
Old sleeve and centerboard pin
Here is the new sleeve and pin mounted in the centerboard. I set with 101 adhesive.
Paint centerboard and ready to remount.
I still have a little play but no longer have the swing that caused alot of banging and cracks in the centerboard well.
New sleeve and pin
Click image for largest view
