Hunter 31 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Stern step
posted 03-29-2015 by captaincarey
Ever frustrated when you can not use your walk-off transom when forced to side-tie?
This works great for us and is an easy modification.
All you need is 2 stainless folding steps, backing plates (I used 1/4 plastic wood) drill 2 holes and some sealant.
When you side-tie just pull the stern in a little and you do not have to climb over the side.
Click image for largest view
