Hunter 38 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Mainsheet twist fix
posted 09-12-2008 by Gordon Taylor
We had a problem with the mainsheet twisting as the Harken block had no way to prevent turning. I was about to buy a Garhauer block with a set screw to prevent turning. We added a plastic cable tie and this has fixed it! no need for a new block.
