Hunter 270 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Rudder-motor linkage
posted 06-08-2014 by Albert Fischer
Rod available from Cabelas snaps easily into supplied fittings allowing to synchronize rudder an propeller orientation for ease of maneuvering within narrow spaces. Rod is stainless steel and cat be cut to size if needed.
Click image for largest view
