Hunter 23 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Singlehanded mast raising rig for H23
posted 10-07-2008 by Peter Suah
Basketball included to show scale
View of assembled rig from port side
Basketball to provide scale. Note angled ends of each pole.
View of assembled rig from bow
Assembly is shown loose for clarity. Note the two steel rigging tangs sandwiched between the pole ends. The wing nut speeds assembly. When properly assembled, the wing nut should be finger tight.
Assembled bow end from above
Note flattened and angled pole ends, rigging tangs and wing nut.
Disassembled bow end of rig
A 7/8 electrical conduit hanger will fit the H23 stanchions. The rubber inserts prevent scratching. The hanger should be placed on the stanchion with the hole end aft. The hole in the hanger may have to be widened with a file or Dremel tool so the bolt will pass easily. Do not use an electric drill!
Assembled stanchion end
Click image for largest view
