Hunter 216 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Hunter 216 Electrical System
posted 05-05-2010 by Paul Wash
We installed a 92 Ah AGM electrical system this spring. In addition we:
- Installed a bulkhead under the port side cockpit seats
- Installed a mast light
- Installed a mast top VHF antenna
- Installed a mounted VHF radio
- 700 watt inverter
- 4 circuit fuse panel/switch
- 1 dc car adapter
We attached the bulkhead using stainless screws and 2 part epoxy. In fact, all mountings were attached with 2 part epoxy and stainless screws. The mountings are all plywood coated with marine enamel. If anyone has any questions please contact me at paul.wash@webnext.net and I will be happy to review the details and specifications of everything we did. Thanks!
