Hunter 216 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Boom tent and boomkicker on H216
posted 10-07-2008 by Jeff Prideaux
My new boom kicker installed. I had cut about 4 inches off the stock length. I am using the larger rods. I will try both the larger and smaller rods while sailing to see what works best.
boom kicker
Last year I was always wishing I had more compartments to put things. This will come in handy.
More cabin storage
For a frame for the boom tent, I simply used some thin line and a piece of PVC pipe. The line goes from the shrouds to the PVC pipe to the stern cleat.
boom tent frame 1
This shows the PVC pipe which will function to hold the lines and tarp up at the stern.
PVC pipe
This shows the line going through the PVC pipe at the end.
line and PVC pipe
This shows the knot attacing the line to the shroud.
knot at shroud
The tarp (8x12) simply drapes over the wire frame. Bungy cords are used to hold it in place.
tarp installed
The stern view of the tarp. The PCV pipe can easily go inside the cabin. The tarp+PVC+rope all cost under $25. I already had the bungy cords. I havent actually tried it out yet except for in my driveway. Ill report back in the small boat forum how it works in real-world conditions.
The topping lift or mast-support shown in the pictures are not part of the setup. Neither are the trailor guides that are shown (my boat is still on the trailor).
tarp from stern
Click image for largest view
