Hunter 386 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
The Tanks are Out!
posted 10-07-2008 by Ron Pearson
See Beginning To Cut.
No Guts.... No Glory! Put the saw to it!
See Middle
The top is Off... What now?
See The End!
The tank is out. It took 3 hours from start to finish to pull both tanks. Im home now and scratching from the fiberglass dust. The tanks were surprisingly easy to remove. They were both leaking from the seam closest to the outlet tube. Will add more pix when the new tanks go in.. Ron
Click image for largest view
