Hunter 22 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
1981 Hunter 22 Bulkhead Replacement
posted 01-13-2013 by John Haynie
Lots of people probably have water damaged bulkheads. When you make a hole in a horizontal surface, water tends to run into it. Our bulkheads were damaged from water intrusion around the chain plates, and also along the bottom from a PO letting the cockpit and cabin fill with water. What a mess!
Click image for largest view
