Hunter 22 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Wood Cabin Floor
posted 11-16-2010 by Mike Canfiled
I pulled the two wood panels out of the cabin floor this week, and started working on them. As you can see from the pic they were in pretty sorry shape. I just started by sanding with 80 grit paper. The little finish that was left on them came right up, and the (for lack of a better term) oxidized wood sanded right away, leaving a nice rich teak and holly color. See pic of before and after sanding. After sanding I rinsed off with water, which approximated the color and look after finished. I ended up using some chemical stripper for getting off the rest of the previous finish, then another light with sanding 220 grit paper. Then three coats of spray Minwax varnish. I will post a pic of a finished panel this week.
Click image for largest view
