Hunter 22 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Mast Holder
posted 10-07-2008 by Vernon Kinslow
The left piece is sized to the outside measurements of the front of the bow pulpit.
The center piece is sized to fit into the dip in the bow pulpit. The length of the right hand piece is the width of the left hand piece.
Mast Holder
The hole is drilled so the right piece top is level with the cut out portion of the unit.
Partiality Assembled
The nylon washer is between the center piece and the locking bar for spacing. I used a SS 1/4 20 2 1/2 screw and locking washer.
Fully assembled
The unit goes in with the locking bar in the vertical position as shown.
Installing the unit
You may have to adjust the tightness of the bolt when you lock it in place. This should be a one time adjustment.
Locked in place
Varnished and with the boat name on it. Not cabinent quality, but it looks pretty good. I am restoring a Hunter 22 and did not like the way the mast was being damaged while being carried in the bow pulpit.
Ready to travel
Click image for largest view
