Hunter 356 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Cheap Companion Way Doors
posted 10-07-2008 by Ron Wilson
I made these doors from under $150 for materials which included teak and bronze acrylic. Most notible features -- they open inward and lock against the companion way walls.
Home Grown Doors for Under $150
Notice they are hinged to open inward instead of into the cockpit.
Open Inward out of the way
Notice the same door closure on the port wall as Hunter uses on their doors. Starbroad side uses a nylon closure into the wall handle. Starboard side opening just about covers the wall handle but the port side clears the handle completely.
From Inside
Both doors open and into each closure.
From Inside at night??
Daylight comes
Anyone for hot coffee from below?
Click image for largest view
