Hunter HC50 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
HC 50 interiors
posted 10-07-2008 by
See View from the rear
Thanks once again to Jim Bohart for the first-ever published photos of the HC50 interior.The project is not quite completed, but is expected to be pristine in time for the Annapolis boat show next week. The detailing is quite different from what you expect in a Hunter: lighter in color and weight, different materials, and configured more for the task of circumnavigation than a summer vacation. Looking forward from a position between the two aft sea berths, just behind the nav sation.
See Galley
The galley, U-shaped for stability at sea.
See Forward harbor berth - view 1
The foward harbor berth.
See Forward head
Heres the nav station, unfortunately shown prior to the installation of the gimballed chart table and seat.
See View from the bow
Looking aft from the harbor berth forward.
See Forward harbor berth - view 2
See Stove
The galley features a diesel-fired stove, to eliminate one more type of fuel (and usually a highly explosive type at that) to stock while underway.
See Nav station
See Hull view
A view of the carbon fiber rudder with trim tab the Yanmar sail drive; the water ballast pick-up tube, and the bulb-keel prior to installation of the composite rotating fins.
