Hunter 40.5 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Line holders
posted 10-07-2008 by Rich Stidger
See Factory original design
On my 1997 h40.5 the line holders that I have are round disks that have a 1/8 line attached. The coil of line to be held is wrapped with this 1/8 line and the line is placed over the disk. The problem is that if you have a lot of line coiled the 1/8 line tends to spread around the disk and come off. This results in the coiled line falling to the cockpit floor in a heap.
See After modification
My solution was to cut the disks at a angle so that the 1/8 line cannot slip up off the top of the disk. See how the line cannot slip from the narrow bottom to the larger top of the disk. Works great!!
Click image for largest view
