Hunter 40.5 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Electronic Schematic
posted 10-07-2008 by Mickey McHugh
See Electronic Component Schematic
This was converted from Visio format to JPG format and downsized so it lost its clarity. The blue lines are Seatalk, red is power, magenta is transducer cables and green is the High Speed Bus HSB that Raymarine uses to connect displays. It a good tool to use to troubleshoot/explain a complex system.
Click image for largest view
