Hunter 380 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Flat Screen TV/Monitor in 380
posted 10-07-2008 by John V.
The Samsung 150MP LCD monitor fits neatly in the bookshelf that normally holds junk.
The DVD player is from Farm and Fleet for $59. The DVD isi on the middle right next to the white nav table light and above the instrument with the white cover.
Monitor/TV overview and DVD player
Ths two are wired to the 12v TV breaker, along with the powered antenna module so everything goes on at once.
Both units are also 110v if needed.
I take the monitor home during the winter to use with my desktop.
Wiring
The monitor is secured by one screw and ss loop and is very secure. It nests in the bookshelf like it was made for it.
Securing the monitor
Click image for largest view
