Hunter 37-cutter Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
26 holes plugged, next?
posted 06-22-2012 by bommers
The step at the base of the companionway needed to be R and Red, so I dug into it and found 26 holes. After a quick grind with the ol counter sink bit, I plugged the bottom of the holes with papertowels and made sure there was a deep bowl for each so the resin could adhere, and then did the resin then gelcoat routine and finished it off with some non-skid. Im happy knowing that there wont be any more rain leaks from that source. Now, on to the next rain leak.
Renasci
Click image for largest view
