Hunter 37-cutter Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
lonseal sole
posted 10-07-2008 by Richard Shelby
1981 Hunter Cutter galley sole teak and holly veneer plywood after 27 years of abuse.
galley before
Lonseal floor after application. One trick: cut a pattern out of cheap vinyl. Primary tool was a utility knife and a straightedge.
galley after
bilge panels removed,taken home and done first to get the feel of the stuff. Port and starboard panels cut from pattern of cheap vinyl. Lonseal glue applied to one end after fit assured. Second half applied after first half sets.
main cabin before
six hundred dollars an one afternoon later...
cabin after
Click image for largest view
