Hunter 37-cutter Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
H37C with new Yanmar 3YM30
posted 10-07-2008 by Dave Wilson
See Completed installation
View of final installation. The 3YM30 has been a great engine for the my 37C. Tom List of List Marine in Sausalito did the installation. He had to move the engine aft in the engine compartment and put a longer propeller shaft in. The 3YM30 is so much smaller than the old engine that if he had used the existing shaft the engine would have been so far back it would have been difficult to get to it. He also matched the engine with a new prop. We selected a 16x10 3 blade fixed prop. I dont worry about the loss of speed when sailing.
See Port side mount
The motor mounts used the existing stringers. They had to be shimed about a quarter of an inch.
See Starboard mount
See Stern view
I also added a dripless packing bearing
See View from above
Sweet little package.
See Propeller shaft
View from the back of the transmission to the packing bearing.
See Attempted close up on motor mounts
See A better close up
Notice the shim under the mount
Click image for largest view
