Hunter 37-cutter Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
offset prop drive 37 cutter
posted 10-07-2008 by Chester Purszynski
this is what happens if you pick up something unseen left in the water after hurricane CHARLIE. It was someones dock with a piece of line that wrapped around the shaft and stalled the engine...boat came out today and insurance is taking care of it..
offset drive
it is a good thing that it didnt rip it right out of the boat
offset drive
i had a shock absorber between the 2 halves of the coupling and i hope that saved the transmission and engine.( i ran the engine after the event and it seemed ok)
offset drive
Click image for largest view
