Hunter 37-cutter Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Replacing Gray ports with Beckson Rain Drain
posted 10-07-2008 by Jim Legere
I ripped out the leaking and crumbling 20 yr. old Gray ports and let everything air dry for about 3 weeks
Taking the plunge
Once the core was good and dry, I took a router with a 3/4 dado bit and cut back the core about 1/8, leaving the fiberglass skins on either side to form a lip for the epoxy putty to fill flush with. Note the inner headliner will also be bonded.
Routed the core
Lots of West epoxy thickened with microfibers. The C-clamps are holding the headliner tight against the cabin structure, while the epoxy sets.
The messy part
With the epoxy set and clamps removed, it looks rough, but at least water cant get in the core anymore. Note the old drain channels for the Grays are filled in and the new channels for the Raindrains are cut outside.
Still pretty rough
The 5 x 12 ports fit right in the old holes, but the Beckson 7 x 14 port is not as wide as the Gray, so some mahogany Dutchmen - little pieces of wood - have been glassed in to make the hole narrower.
Dutchmen
Here is a 7 x 14 Beckson Raindrain, with the dutchmen showing. The trim ring will cover them.
Final fitting
Lots of silicone used to bed the ports in. Clean up with an exacto knife and a razor blade scaper once dry. Sit back, have a beer and admire ones work...Ah!
All done
Click image for largest view
