Hunter 37-cutter Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Anchor locker modification 37C
posted 10-07-2008 by Scott Wilson
View of anchor locker with cabinetry removed. Dead space around sides and below loacker pan. Also I had a leak from the bow area of deck that collected in/or on v berth. Gray squares on sides are the carpet outline of shelves removed.
The space waster
Used 5/8 inch ply that fit into the tab of the deck liner, at the ceiling line. I ended up glassing over the bottom bolt of the chain plate on the forward side of the chain plate, so resolve the leak issue.
view of replacment locker aft bulkhead
YOu can see that the locker has increased in depth about 90%. Per this forums advise, slack the foresail stay before cutting out the old locker sides, keeping the rear/aft wall of the original locker.
new locker floor glassed in from below
note I glassed over the bottom of the chain plate to prevent (reduce?) potential leaks.
closer view of glassing original locker to new
new through hull is the lower foward one, I left the glassed over (from inside) throgh hull drain rough for photo purposes
through hull drain was moved
I kept the bitter-end u bolt from the old locker and installed in the new floor
using new locker,
Crew enjoying the boat on Puget Sound, Seattle
Click image for largest view
