Hunter 37-cutter Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Water Tank Fix
posted 10-07-2008 by Richard Shelby
See tank1
What the inside of a 20-year old aluminum tank looks like. This baby was leaking at the rate of about 50 gal/48 hrs.
See tank2
After cutting off the top of the setee, the top of the tank, and the two baffles, AND grinding off the burrs left on the inside.
See tank3
The plastimo 40 gallon bladder in place.
See tank4
The setee fiberglass screwed back in place. Two days of grinding and cussing.... A shop vac full of aluminum, fiberglass, and carborundum disk fragments... At least I now have some options. If the bladder is empty, I have a new storage compartment. If the bladder decides to leak, I can yank it out in minutes. I will not try this on the starbord tank, but rather cut access ports, and seal it with epoxy. More later..... RS
Click image for largest view
