Hunter 37-cutter Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Chart Shelf
posted 10-07-2008 by Bob Miller
See Chart Shelf
There has been some discussion in the past about chart storage. Here�s my solution on my 1984, 37 Cutter. The two sides are solid teak the same thickness as the nav table brace, just for consistency. The bottom is 1/4 inch plywood. The side facing down is finished teak. The side facing up is white. I don�t know what it is, but it is the same finish as the other original equipment bulkheads. I wanted a smooth finish for easy sliding in and out of the charts without tearing them, or whatever. Notice the solid teak strip mounted on the nav station bulkhead, underneath the shelf, for addition support of the shelf.
See From a Distance
The second photo shows the shelf from a distance just to show that the shelf is out of the way and not knee-knocker.
Click image for largest view
