Hunter 37-cutter Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
The Ol Stuffing Box Blues
posted 10-07-2008 by Ron Pearson
The stuffing box before removal of packing
Stuffing Box
After nut is loosened. Water begins to come into the engine compartment.
Stuffing Box
Nut is completely backed off and stuffing is removed. The total job takes about ten minutes and the amount of water entering the boat is less than two gallons because the clearence between the prop shaft and the housing is from .040 to .060. The bilge only came on twice.
Stuffing Box
Click image for largest view
