Hunter 37-cutter Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Replaced thru Hull
posted 09-12-2008 by Renasci
No pics from before, but it was the usual, wood wet, swollen, separated, bearly keeping the water out, inline valves, dangerous stuff. I put these in about two years ago and Ive been very happy with them, thru bolted, starboard custom shaped for each and 3m 4000 fast cure. Now its a little beefer, huh...
