Hunter 37-cutter Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Galley Engine Divider
posted 09-12-2008 by Renasci
Greetings, this past weekends adventure included replacing the divider between the galley and the engine comparment/aft lazarette area. The pics start with a usual before, during, then after. I have more trim to put up, then its glue and saw dust to cover the small screws, then varnish, but you get the idea. It was a whole lot easier then I first though. There were a couple of screws that came out from within the aft birth, a couple from behind the cupboard/frig, and a couple unscrewed from the aft lazarette.
