Hunter 35.5 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
V Berth Water Tank Access Openings
posted 10-07-2008 by James Rushing
See Port Access Opening
This is the access opening added to the V berth floor on the Port side. Through this opening I can check the Snake River foil sending unit for the water tank. It also allows me to inspect the rear side of the water tank.
See Starboard Access Opening
This opening is cut in the V berth floor on the Starboard side. It allows you to inspect the water line connection from the tank to the pump.
Click image for largest view
