Hunter 35.5 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Snake River Ultra 8 System
posted 10-07-2008 by Jim Rushing
This is the new panel that replaced the older Snake River LCD-102 panel. The older panel was fine for smaller tanks, but not accurate enough for larger tanks. New panel indicates ten different positions and old panel only had five different indications.
Snake River Ultra-8 Gauge
This is the new 25 gallon holding tank that replaced the original 13 gallon aluminum holding tank. Snake River foil sensor is mounted on the left end of the tank. Originally used a Snake River metal tank probe with a LCD-102 panel when the aluminum tank was part of the system.
New 25 Gallon Holding Tank w/ Level Indicator
This is the water tank in the bow area with a Snake River foil senser mounted on the right side.
Water Tank w/ Level Sensor
Click image for largest view
