Hunter 35.5 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
H35.5 Custom A/C Installation
posted 10-07-2008 by Jim Rushing
Back in 1997, I asked Artic Air of Clearwater Florida if they would package one of their 16,000 btu Heat Pumps in a special way. I sent them a series of cardboard templates of the area inside the starboard locker on my Hunter 35.5 sailboat. From this, they built the unit to fit into the locker. This first picture is the starboard settee with the heat pump and ductwork. Air from the blower exits in the aft direction. The duct feeds a splitter that divides the air for forward and aft directions.
Starboard Settee with Heat Pump
Starboard settee with top on. Axial blower in forward duct under settee top. This is needed inorder to keep the air volume high enough.
Starboard Settee
Starboard settee with AC air intake and duct going aft.
Starboard Settee
Aft duct under chart table with built in vent for Galley area. Duct passes through head area and contiues into aft cabin with vent outlet there.
Duct under Chart Table
Another picture of aft duct under the chart table and TV storage area.
Aft Duct
Sump area with AC water intake, filter and pump.
Sump Area
Forward cabin locker with air splitter and ducts for AC outlet for V Berth and Main cabin.
V Berth Locker
Main cabin with AC outlet. Vanes are adjusted to spread air across the cabin area.
Main Cabin Outlet
Click image for largest view
