Hunter 35.5 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
two 50 Watt Solar Panels on Hood
posted 01-11-2020 by Steverhnm
Click for larger view
Two 50 Watt panels using a location otherwise not used. Fabricated small aluminum angle for mounts. Took the hood off to do it, no problem., Shadows are diffuse so do not affect output very much.
Copyright 1997-2024 SB Owners, LLC
All rights reserved.
