Hunter 340 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
A better shower set up
posted 09-08-2013 by Levin
I always felt that the shower set up in the Hunter 340 could be improved. First I didnt like where the factory set the shower sprayer to begin with. Unless you are 4 1 this didnt work too well. Im assuming they did this because they wanted to avoid getting the rest of the head wet, but it still managed to get everything wet and you had to duck down a lot simply to get under the water. So I moved that, and I added a shower curtain to keep the rest of the head from getting soaked, and now I can take normal adult showers on the boat with ease.
Click image for largest view
