Hunter 340 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Replace Jabsco with PHIIc
posted 10-07-2008 by Andy Falls
The new PHII on a compact base fits to the aft (stage left, or to the left as you sit on the head) from where the orginal Jabsco fit.
Installed to aft
The PHII uses a lever type pump handle that sticks up higher than the Jabsco pump. Therefore the shower seat/cover wont go all the way down with the lever in place.
Lever obstructs shower cover
You can easily remove the lever and the lid will go down to the planned position. (This was you can also keep the handle out of the hands of abusive head device destructors!
Temporary removal of lever
Click image for largest view
