Hunter 340 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Hard to raise mainsail pt 2.
posted 09-12-2008 by g
I also had difficulty raising the main on my 340, but discovered that if I release the mainsheet and the boom vang when pointing into the wind, the sail aligns itself and raises much more easily. It usually goes three quarters of the way up without the need to use a winch.
Hope this helps,
g
