Hunter 34 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Propane furnace installation in H34
posted 10-07-2008 by Jerry Keto
Kicking out about 6,000 btu, this heater is fantastic for early spring and fall warmth or supplemental heat in winter.
Propane furnace installation - Force 10
It installs very simply on bulkhead and the chimney (not supplied with heater) is made from standard 1 SS pipe used for dodger framing.
Bulkhead mount
Also adds some ambiance
The chimney cap is included but not the teak rings. Ive never had trouble with water intrusion.
Chimney cap
Click image for largest view
