Hunter 34 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Leaking Port Damage
posted 10-07-2008 by Ray Keenan
Appears to be some minor damage from leaking port.
getting worse as I inspect further
After removing shelves and everything else... found considerable damage due to no place water leaking through old port and down inside the shelf. Water lays on top of fiberglass ledge that supports shelves. Removing these two pieces was a major job.. not difficult just slow going... a lot of screws.
Underneath
damaged stbd side
Click image for largest view
