Hunter 34 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Cheap Refrigeration
posted 10-07-2008 by Ray Keenan
See Condenser
Installed in compartment next to Ice box. Mounted compressor with original rubber mounts and is super quiet. Condeser attached to side of boat with adhesive mounted electrical ties.
See Evaporator
This is the evaporator installed to the upper rear part of the ice box
See Hole to put evap thru to Ice Box
Also Photo of thermostat control. Out of the way but east to get to adjust.
See Ahhhh cold beer
set on 2 and temp down to 39 F
Click image for largest view
