Hunter 34 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Sailboat Specs
posted 10-07-2008 by Claude Auger
See Sailboat Specs
Old dirty diagram,but it does show all the principal measurements for the boats and the sails. And for those who are still wandering about a 150% or 130 or 110, etc, it is simply the LP/J ratio. Of course the greater the ratio, the greater the surface area of the sail. The J measure goes from the base of the mast to a point in line with the stay attachment point. It is calculated at a precisely 90 degrees angle from the mast. SPL stands for Spinnaker Pole Length and G stands for the Girth of the spinnaker. LLJ = Luff length Jib. LLS = Luff length Spinnaker
Click image for largest view
