Hunter 34 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
83 Hunter 34, various upgrades
posted 09-12-2008 by Richard Bennett
Lizzy Bee at Lowestoft. Note the AirX wind gen on Pole, Radar reflector on backstay and Island nautical Sprayhood.
With Hucky our Jack Russell.
The cracked rudder after grinding out and before 2 layers of GRP and 5 coats of West Epoxy.
The port side cabin locker epoxied ready for the batteries.
The 4 batteries fitted. The engine starting battery is in the engine bay.
I cut away the divider to make better access and added a suport brace underneath.
I fitted a rv water filter before the pump and a 10A battery charger in the same locker.
the water pump and end panel to seperate the batery box from the rest of the locker.
The two valves relpaced the 4 way valve as it leaked.
I also added a baffle in the floor to stop the shower water from getting into the port side to keep the main bilge dry. The shower floor has its own automatic pump..
The end panel of the port bunk and the sender for the water tank gauge
Cutting away the internal cabin moulding to make way for the radio gear.
The nav station.
And again.
The Nav seat.
The starboad side aft Locker. Cutting away the tray.
After 2 layers of GRP and white epoxy.
The washboards after sanding down and 2 coats of epoxy.
The washboard reinforced with 1/2 ply and cut into 3 pieces and tied to the boat.
