Hunter 33_77-83 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Hunter 33 C Holding Tank Modification
posted 02-25-2012 by H33CRich
This is a fairly standard modification of the H33Cs waste holding tank/bag. It is a big job but I feel necessary to eliminate malodorous permeations coming from an aging waste bag. You can get the latest updates from http://www.richgard.com/holding_tank.htm. I am also including a print-to-pdf version.
Click image for largest view
