Hunter 33_77-83 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
Raritan PHII in Hunter 33
posted 10-07-2008 by Sam Lust
HDPE about 1 1/2 inches thick. Multiple angle cuts
Spacer plate, view 1
spacer plate, second view
Studs sticking up from floor. Hole allowed nut plates to be placed below
Floor prepped for spacer and toilet
Plate is nutted down, several are counterbored to allow studs to be flush to surface. Toilet held down to plate with stainless lag bolts
Toilet mounted on plate
Spacer plate allows toilet to be centered side to side
Centered
This is a High-Boy toilet with a standard residential size seat. In some areas comfort is simply a requirement!
View from above
This allows toilet to be pushed back as far as possible , enabling wider swing of vanity door.
Flush water spigot recessed into bulkhead.
This was made from a full size template that I made up and sent to the fabricator
Custom welded holding tank
View from the back
Fresh water pump and flush water seacock were there. Pump now on bulkhead, sea cock moved adjacent to engine cooling seacock and prop shaft.
Looking into sail locker
Its about 17 gallon, about all that would fit in through the seat/hatch. Floor was cut out, plywood filler made up.
Unused space below sail locker filled with holding tank
Click image for largest view
