Hunter 31_83-87 Owner Modifications and Upgrades
Hunter OEM Parts
General Marine Parts
New Head w/ PVC Pipe
posted 10-07-2008 by Patrick Lombard
Parts used for job plus a 10 piece of 1 1/2 PVC pipe.
Parts
Looks OK but pump parts worn-out and rebuild kit cost $65.00 New head on sale for $119.00 with $20.00 rebate. A no brainer.
Old Head
Install new hoses 2 years ago. Odor started again. Old trick is to wrapped in plastic wrap to keep down the smell.
Old Hoses
Old Hoses
Old Hoses
Cut and fit all parts and index mark all fittings in their proper angles, before gluing.
New PVC Pipe
Pulled out old hose from head.
Old Inlet Hose
Could only fit a 48 lenght of pipe under the V-berth, then feed pipe back to head along the hull of boat.
New Inlet Pipe
A shot of the PVC pipe being feed past an inspection port.
Feeding PVC Pipe to Head
Had to file and sand the hole a little to get the PVC pipe through opening.
PVC Pipe at Head
Because I could only get 48 of pipe under the V-berth I had to add a 16 extension to the pipe to reach elbow on new head. What I should have done was to add the extension to the other end under the V-berth. It would have looked better. O Well!
Add Extension
New Head Joker
New Head Joker
Hooked Up Head
New Head
I can shut off the flow from the tank if I need to work on the system.
Tank Outlet Valve
By opening and closing valves, I can direct waste to the deck pump-out or to the macerator pump. Works like a Y valve, a little more work to operate but alot cheaper than a Y valve.
Valves For Deck Pump-Out
Here is a shot of the inlet pipe from the head to the tank. I used flexible 1 1/2 female to female couplers to connect the PVC pipe to the fixtures.
Tank Inlet
Click image for largest view
